WD Loader Max Capacity?
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: WD Loader Max Capacity?
    Posted: 22 Feb 2010 at 9:22am
So I went to pick up a drawbar and plow for my B this weekend, but when I got to the guy's barn he said he didn't have time to get the drawbar off of the C rear end that it was on. So he gave me the whole rear end, torque tube and plow for the same price we had originally agreed on... the only problem now is that the rear end is sitting in the back of my parents' truck. Everything else I could lift out by hand.
Needless to say, they're not terribly happy about it. I had planned on lifting it out with my Dad's WD as it has the front trip bucket on it, but now I'm wondering if it is even designed to handle this much weight. Oh yeah, Dad insists that his tractor is fine, but it wouldn't start... the carb float was stuck and then the battery died. Oh well, it's his tractor, not mine.
I don't know the model of loader, but it says "Allis Chalmers" on the tag so I assume it was from the dealer. It was also made in Peru Indiana, I believe. Any ideas as to how much it can lift would be appreciated!
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 9:30am
After using mine during storm clean up, I'm sure it will lift it. I lifted 12 foot pine logs, 32" in diameter. I would recommend just lifting it and drive truck out from under it. Then you can lower it until it just clears ground to move it. HTH God Bless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 9:34am
Nice! I hadn't even thought about driving the truck out from under it. That will make things a lot simpler, thank you!
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 9:36am
Sounds like good advice from Bob on the loader.  Just wondering though, are you planning to use the C's drawbar on your B?  The B and C don't use the same drawbars, as the C rearend is about a foot wider... give or take a little.  Just trying to be helpful... I hope it came out that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 9:39am
Ahhh... you're right about the drawbar, dang... should have thought of that. Probably why I got the deal, oh well... at least the mounting brackets should work, and I can pick up a drawbar at the junkyard over the summer.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 12:50pm
AS I remember the WD9 loader we got new in 1957, was rated at 2000 pounds.
We had to put in extra shim washers for higher preasure and some wheel weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 1:47pm
As long as my back wheels stay on the ground, I've never had a problem lifting anything with my #9 loader on the 45. If it's too heavy the pump will bypass. Mines only running about 2800 psi.
LarryWC In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 2:19pm
I'm proud to say I picked up a whole frame, transmsision and rear end of another WD45 with my WD9 trip bucket!
And other then NOT having power stearing making it HARD to turn once in the air, it picked that whole thing up with ease!!!!
Edited by LarryWC In - 22 Feb 2010 at 2:20pm
www.allischalmersmuseum.com
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 4:06pm
I picked up the back of My pickup with and extra engie in it with My WD45 & 109 Loader.
Stuffed Planks under it and drove it out of the mud. Could not move with the truck off the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 4:25pm
this is what I picked up!,,not sure what it weighed,,but it was heavy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 5:48pm
This is definitely comforting to know that the WD shouldn't have any problem lifting the rear end. Looks like I may very well be piecing together a C from mismatched parts after I get my B going lol!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:25pm
I was able to lift a complete WD, minus the rear wheels and fenders, by the back axle with my WD and pull it out of a field on the front wheels!!  I was amazed!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 7:51pm
This is good information, I'd like to find a good WD9 loader to go on my WD45....that little short-line itty-bitty loader on it now won't lift much.  I'd like to be able to fetch plows & other snap coupler stuff on and off trailers w/o spending a bunch of money.  I know some people say those old loaders go for like $100, I'm still waiting for one of those deals, LOL!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2010 at 8:09pm
I don't know anything about the C's,  but that looks a lot like a WD or WD45.
Have you looked for the serial number on the rear end?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryWC In Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 9:07am
Gary,are you asking me about that picture?,,if so YES, that is serial #207220 WD45.
it is now up on it's wheels but still have a way to go with it!
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2010 at 4:10pm
ac's will do any thing
