HD5G throttle control lever quit
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: HD5G throttle control lever quit
    Posted: 28 Jan 2014 at 9:00am
maintaining position. It goes back to idle position if not held externally. I finished my job earlier this week by placing a "stick" between lever and housing (very professional, eh?). I looked in the service manual to see what the inside looks like. Just trying to get a jump on things while too cold to work outside (+8*F this AM), what usually fails inside these things? I'm hoping its just a broken spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 10:15am
Two different designs were used on throttle control , both using a friction device to hold position . One is thin pancake appearance and later is thicker unit with a bolt showing on the one edge . ( tighten the bolt some ot increase friction. )
This page was generated in 0.367 seconds.
