10hp Briggs |
L Hud
Topic: 10hp BriggsPosted: 16 Jan 2014 at 5:45pm |
Recently put a coil on the B10 when the mag went south. Also put in a new set of points. Now the exhaust will get red hot in a short time. Will this be caused by the points not adjusted to the correct gap? Any help appreciated. Hud
timflury
Joined: 10 Apr 2013 Location: Mukwonago, Wi. Points: 17 |
Posted: 16 Jan 2014 at 7:15pm |
Yes it will.
Did you install a new condenser with the points?
When was the last time you thanked a veteran.
L Hud
Posted: 16 Jan 2014 at 7:53pm |
Yes I put all new. Points and condenser. Thanks for the reply. Hud
gordonh
Posted: 16 Jan 2014 at 9:13pm |
Adjustment of point is off. I think it is 1800. Could be the key in fly wheel partial stripped.
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 16 Jan 2014 at 10:29pm |
Points should be gapped at 20 thousandths. |
L Hud
Posted: 17 Jan 2014 at 5:57am |
Thanks guys. Hud
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4065 |
Posted: 21 Jan 2014 at 1:26pm |
did you use briggs mag part number 298968 mag 26018 points 298060 condensor or did you wire up a 12 v coil it has have the timing way off probley retarded to far we had a customers model 32 briggs quit running and when we figured it out the flywheel magnet had changed polarity and had to find new flywheel but it would run almost firing on exhaust stroke
L Hud
Posted: 23 Jan 2014 at 6:20am |
I used a 12v. coil. I bypassed the mag and used the points to fire the coil. I sort of eyeballed the points. Have not gotten back to it yet. May be spring before I mess with it again. Thanks for the reply. Hud
