917H
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: 917H
    Posted: 08 Jan 2014 at 6:03pm
what would a non running one be worth, seller says needs battery, and carburator rebuilt. comes with mower deck[needs new blades], snow thrower with loose  chain drive sprocket.  decent paint and tires.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2014 at 7:34pm
WELL YOUR ARE LOOKING AT ABOUT $125 TO $150.00 WITH BATTERY BLADES AND CARB REBUILD, AND I WOULD ALMOST SAY IT WILL NEED BEARINGS IN THE DECK, BUT IF THAT IS ALL I WOULD SAY AROUND $250 I GAVE $125 FOR THIS 712H AND 48 IN DECK RUNNINGBUT I NEED TO PUT BEARINGS IN THE DECK, THEY ARE NOISY.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2014 at 8:36pm
Make sure it has the Series II engine. The Series I Kohler KT twins had lubrication problems. If it has a rear lift kit that is worth some $$$. Does it have hydro-lift or manual? If the blower is an easy fits thats another $100-$250 of value. In tip-top shape a 917 with blower and 48" deck could bring close to $700-$1000. An average good runner w/deck is probably $400-$700 depending on the location and timing.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2014 at 5:59pm
"carburetor rebuild" could be masking bad engine problems. Maybe carb is ok and it is really an engine problem.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2014 at 3:50pm
My 917 dont idle correctly,---(has an 18 hp in it--the guy tossed in the old 17hp, so I still have the little engine)---he thought it was carb problem,--I think its more governor related myself!---will find out this spring when I can get out there to work on things! thanks; ac fleet
