Oxnard Blade Question
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Oxnard Blade Question
    Posted: 18 Feb 2010 at 3:31pm
I am sure that I've posted about this before, but searches keep coming up empty. Sorry for bringing this up again, but I don't remember the answer I got before!
I am rehabbing the blade tilt adjusting screws on my blade and have a question about the pin that secures the end of the screw behind the trunion that's attached to the blade. I've "adjusted" a cotter pin which works but clearly isn't the original scheme. Was that pin a roll pin? Something else?
Thanks much.
WC, CA, D14, WD45
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 4:37pm
I just went out and looked at one . It looks like a solid pin reveted in the collar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 4:42pm
Hi Richard - how are you? Thanks for the reponse.....of course, I have another question! You mention a collar - are those available anywhere? I've got a mental picture of what you're talking about, but a real picture would help. Any chance you could post a picture of this collar? Or suggest its dimensions?
Thanks again.
Edited by Dave(inMA) - 18 Feb 2010 at 4:44pm
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 4:47pm
Just wate a minute, I took a picture while I was out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 4:48pm
Richard, you're too much. LOL
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 5:09pm
Here is two different ones .
The old style , color and pin
The newer , threaded nut and cotter pin
I just used the big blade to clean the lane.
Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 5:22pm
Richard, thanks a ton for the pictures! Mine is the old style. I think I will need to make some collars.....looks like the width of that collar is about 0.5"....sound about right? The diameter of the shaft end is 0.75", and I can measure the outside diameter of the collar as I have one of the screw setups completely disassembled.
But before I get into the machining business, does anyone know of a source for collars of that size?
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 5:40pm
Dave , these might work.
Richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 6:02pm
Thanks, Richard. I have been checking the catalogs online.....lots of set-screw collars, none with a straight-through pin. If they're not hardened steel, I can drill them out. I am also blessed to have a friend with a very complete machine shop and the skills to go with it! LOL
WC, CA, D14, WD45
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2010 at 11:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 6:16am
You're best to make a couple sets of those collars while in the machineshop.I'm sure you could easily sell them on this forum or at least have some spares!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 9:20am
Gary - thanks much for the link to my earlier post. Still puzzled as to why it didn't show up in a search, but that can wait for another day! jaybmiller - will see about getting into the collar manufacturing business - good idea. LOL.
Now I am onto thinking about why both collars are missing on my blade. Is it common for them to be missing? Could it be that the pins used to loosen and slide out? Or maybe fellows got tired of driving them out and replacing them when the screws were bent from heavy use?
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 9:41am
I don't have an Oxnard blade but if I had dimensions of the collar I'd bet I could find something like Eldon was talking about in the other post. You would just have to drill out the threads for the set screw and drill through the other side for the roll pin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 12:06pm
CTucker - yes I could. Thanks for the suggestion. If the local machine shop option doesn't work out, I will try Eldon's approach. One key reason for going this route is that it will get me some time in the machine shop doing this myself....falls into the personal choice category for a retired guy like me!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2010 at 8:09pm
Happened to be in the local hardware store this afternoon - they had set screw collars in just the right size. Almost bought a couple!
WC, CA, D14, WD45
This page was generated in 0.049 seconds.
