|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Allis chalmers tracters |
| Post Reply   |
| delbertstringer   Bronze Level   Joined: 18 Feb 2010 Location: Nevada Points: 1 |  Post Options  Thanks(0)  Quote  Reply  Topic: Allis chalmers tracters Posted: 18 Feb 2010 at 2:50pm |
   To whom it may concern, why wont my govener gear engage with my timming gear ? anyone have sugetions ?
 allis chalmer WD45 Gas tracter  | |
| Chalmersbob   Orange Level   Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Feb 2010 at 8:36pm |
| How do you know the gear is not engaging? The gear could be stripped, or a pin could have sheared off on the drive for the mag/distributor. The only way you are going to know for sure is to tear it apart and see what you find. Bob | |
| Ken in Texas   Orange Level   Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Feb 2010 at 8:49pm |
   I presume you took it apart and are trying to put it back together. Were they meshing correctly before you took it apart?
| DREAM   Orange Level     Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Feb 2010 at 8:58pm |
   Not sure if it's the same, but I had a problem with the mag on my C. The rotor button was not turning after I set the points and cleaned everything(this was when I first got it, trying to get it started for the first time.). Found that someone had left the gasket off between the points cover and rotor section. This caused the rotor gear not to mesh with the mag drive gear. I cut a gasket for it, solved the problem. Is the problem you're having that the rotor button won't turn, or can you not get the governor gear to go back into the timing gear? Is it binding and won't go into the hole?
| Ken in Texas   Orange Level   Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |  Post Options  Thanks(0)  Quote  Reply  Posted: 18 Feb 2010 at 9:12pm |
   The gears are not straight cut and its a little tricky to get the timing marks lined up. Maybe this is what the original poster is trying to say. I like to have gone nuts timing  a B because both the marks were on teeth and not on a tooth and a gullet.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
