wc piston in 226
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
woody4178 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody4178 Quote  Post ReplyReply Direct Link To This Post Topic: wc piston in 226
    Posted: 28 Dec 2013 at 6:58pm
I have a 226 4 1/8 bore 4.5 stroke out of a wd45 am wanting to put wc pistons in it I am tryin to avoid stroking it. Question is will this work,what are the wc pistons compression height and what kind of compressiom ratio/hp will I be getting. Fairly new to all this looking for advice.thanks
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 1:21pm
Yes you can run flat top WC or WD 4.125" replacement pistons with your combination. I'm running a similar combination but elected to go with 4.125" 170/175 crater pistons. We also used a WD45 block. This combo works out to be right at 240 cid and around 8.25:1 compression, and is good for about 58 hp at 2000 rpm. Depending which flat top pistons you use your compression ratio should be a little higher than ours. KipWink
Edited by Kip-Utah - 30 Dec 2013 at 1:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody4178 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 7:27pm
Thanks kip pretty sure we are guna run wc flat tops 4.125 and s 170 cam
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 7:29pm
Good luck finding a 170 cam....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody4178 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 8:31pm
I did get lucky on the cam father in law hss one already to go
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 8:53pm
Very lucky
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2013 at 10:43pm
isn't it the 175 gas cam that's hard to find? or are they the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2013 at 6:31am
A 170 cam isn't any different grind than a D-17 or "E" Gleaner or WD45 or WC for that matter. The "175" camshaft is the special high lift grind.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2014 at 6:12pm
SR' find you some small block chevy pistons with same rist pin holes. works fine.
bmartin55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmartin55 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2014 at 7:06pm
hi want to do same thing ..i have a 17 gleaner motor..need 4.125 pistons.want to grind crank& use 350 rods..OR 350 sbc pistons..  bob
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2014 at 9:46am
SBC 350 rods?
