For Sale B Parts:
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Topic: For Sale B Parts:
    Posted: 15 Feb 2010 at 5:06am
I am parting out a Allis Chalmers B. Motor is free,rear rims,radiator,tin ect. 785-353-2392
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 5:47am
Are the tires any good? Where are you located?
Kraig (WI)
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
Tyler Williams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tyler Williams Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 2:21pm
Is the deck of the block cracked?
www.pentagonfarm.com
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 3:20pm
If the motor is free, what are you asking for the rest of it?
Is there truth in advertising here?
(:^D
Edited by Dick L - 17 Feb 2010 at 3:22pm
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 6:35pm
The last motor I got that was free came in a for free C. I had it running pretty quick on 2 cylinders so I pulled the valve cover to find 2 broken pushrods. I tapped the valves that were stuck till they popped loose and replaced the 2 pushrods. It ran on 4 but lots of blow by. Hard to time the mag because there was so little compression on #1.  Pulled the head and #1 piston and sleeve are cratered like battery acid ate holes in them. Head don't look to bad with the valves all closed. No big cracks between the cylinders. If I fix it it won't be  free any more. I did get to drive it. The free tranny made lots of noise so I inspected it. The main shaft was floping around in the case like it had no bearings left. I discovered the last mechanic that worked on this C put the front mainshaft bearing in bass ackwards. Can you imagine that?
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 7:29pm
Does it have a pulley?
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2010 at 10:08pm
$40.00 on the pulley. 785-353-2392
This page was generated in 0.104 seconds.
