I-600
willy wagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote willy wagon Quote  Post ReplyReply Direct Link To This Post Topic: I-600
    Posted: 14 Feb 2010 at 10:20pm
the injection pump on my backhoe is needing work and an injection pump repair shop wants $800 to fix it. i was wondering what gas models would fit in this hoe?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2010 at 10:59pm
The 149 and 160 engines from a D14, D15 or D15 SeriesII  farm tractor will all fit...holes in the hood won't match up.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 9:13am
Fixing the injection has to be cheaper than buying and swapping a engine?
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 9:46am
try a diffrent shop.  Iam with Dmiller with this.  no way could you swap motors unless you already have one.
160 CA 920diesel 5020 HD-3
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 6:14pm
a diesel is much better in the long run also. you will get better life and horsepower out of it. with a rebuilt pump and injector work you will be surprised at the power and lack of fuel consumption.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 6:47pm
There are  a couple good guys on here that do pump work.  On my HD3 someone recommended a guy on ebay that rebuilds pumps.  I sent mine to him and he also went through and cleaned and checked the injectors.  With shipping, I think it was a little over $400 round trip.  That's a far cry from 800.  If you're interested, I will try to find the receipt from him.  I think I sent it off around thanksgiving and got it back in less then two weeks and that included the holiday week.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 7:58am
If your are using the machine a lot. Stay diesal I know they are alittle less power. But us a lot less fuel. And the HP is a lot differant when running a hoe. Had a gas hole (IH 3616) and went to a allis 615 diesal. Was night and day as fare as working underload. The gas was quick to bog down and slow to recover under load.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
