OLD Tractor Fork Lift
Okwen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Topic: OLD Tractor Fork Lift
    Posted: 29 Nov 2013 at 6:44am
Hello, I am new to the site. Just picked up an old allis chalmers fork lift and am looking for some info on it. I think it is a I-60 but am not sure. Just want to findout a few things to give it some TLC like what hydraulic oil to use for the lifting. It has shuttle shift, and everything seems to work decent, needs some new roller bearings and the chains oiled but seems to work. Any help on this would be great.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 12:22pm
I bought one just like it last summer, great tractor to have around. I just run regular hydraulic fluid in mine.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 1:59pm
Link to 'Tractor Data' website:
Specs. for Allis I60
Gary
http://www.tractordata.com/industrial-tractors/000/0/8/84-allis-chalmers-i60.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 6:04pm
Looks like I 600, series 2 muffler, and a hard nose radiator shell, although it could be a johnny cash put-together!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 6:15pm
Thanks Gary. There is a little info there. I am also looking for the roller bearings that are in the rails of the fork lift, so if you or anybody know where to get them that would be a big help.
She fires up a drive quiet well. I started her this morning and it was 6 degrees F without any trouble.
Thanks Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 6:28pm
I think for the bearings you might have to pull one off and order one by measurements from a parts store. Probably not the kind of item on any old Allis dealers shelf.
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 6:48pm
if you mean mast rollers typically the bearings are not replacable separate from the roller. you may be able to get them from a bearing supplier but i'm not sure. a good forklift dealer should be able to help
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 7:37pm
Yhea i meant mast rollers. That's probably what i will have to do is take one off for measurement and see what I can get.  I hope to give the old girl a little love. the rollers on it have some flat spots, the mast still goes up and down but the rollers don't roll. I tested picking up an old chevy caviler, it got it up off the ground but didnt want to much higher than a few feet, it would tilt in and out with no problem but didnt want to g any further, could tell it it was just the rollers binding. I picked the thing up for 1500 and the guy had just put a new alternator on it and had the carb rebuilt. I am going to change the hydraulic fluid, seems a little thick and want to make sure it's clean. Not sure what to use though. It's a little tough to steer when it's below 20 deg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 7:38pm
Sorry meant couldn't tell if the rollers were binding
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 7:46pm
I recently brought home some I beams from work that weighed just over 5000 pounds each and at first the steer wheels came off the ground when I tried to lift one so I added 1500 pounds on the counter weight and then I could tilt the forks forward and bring them up tight to the beam and tip the forks back to lift it. It would not lift it straight up but I could still steer with the extra counter weight. I'm guessing they are rated at around 4000 pound capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 7:54pm
Ok good to know. Any thoughts on why it didn't want to go higher. Think the cold would have anything to do with it, or thick oil? any ideas would be helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 8:00pm
If it wasn't binding I think the only reason would be lack of oil because if it lifts the entire car off the ground a foot it should lift it all the way up. It takes a lot of oil to fill the lift cylinder and I'm not sure how much extra is in the reservoir, if it's a little low that might do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 8:01pm
I've seen rusted chains stop them  dead. we even had a rep from mit/cat forklift tel us the only true way to lube the chains is to take them off and soak them
Edited by Mrgoodwrench - 29 Nov 2013 at 8:02pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2013 at 9:37pm
The mast rollers may be something that you could find if you do a search for "Cam Follower". It's a common industry style of bearing that's intended just for the purpose of following a rail... very handy.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2013 at 9:33am
If you want to know exactly what you have look at the bell housing. The model/serial
number should be stamped on the bell housing on the same side as the carburetor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2013 at 3:49pm
I did find the serial number right after I had made the first post. So I went over things again and did another test lift, and yup it seems that its the rollers that are keeping it from lifting anything heavy very high. So new rollers is top priority. I will look at napa, I also went to an old school tractor store that use to be an allis dealer years ago. He says he could get them but that they wernt cheap, a 2-3 hundred each roller. I hope i can find them for less than that. i was thinking of around $50 each, $100 tops. See if i can come up with anything this week. But boy is it a hooot to play around on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okwen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2013 at 5:02am
Well I have been making some good head way on the rollers. I went into to a load lifter dealer 15 min from my place and they knew all about what I was looking for. He is just going to give me a newer trolley to be able to put newer style bearings on, because the ones i took off just had a brass bushing.  Had another quick question, does anybody know what the machine weight is? I am not totally sure and don't want to overload the trailer.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2013 at 5:49am
A diesel d-15 II weighs about 4200 #, so add the weight of the mast, and counterweighting, and you prolly have a tractor that weighs in the neighborhood of 6-7K #.
ghostriderinthesky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2013 at 6:50pm
looks like an old KD brand Forklift made in Waco Texas. now owned by Manatou in Waco still has parts.
