wd-45 nf adjustment
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: wd-45 nf adjustment
    Posted: 13 Feb 2010 at 7:59pm
started working on wd-45D today, has a standard NF, there is quite a bit of play insteering wheel, before wheels move, is this adjusted by shimming out the shaft that the worm gear is attached to ??
Cowboy UP
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 8:12pm
You may be able to remove some shims from behind the bearing retainer, but the most play is prolly in the u joint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2010 at 8:22pm
no , its in the gears
Cowboy UP
