.wc numbers
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: .wc numbers
    Posted: 14 Nov 2013 at 9:36pm
I'm stripping the ole WC down and do not no the year or anything about it. Was wondering if someone could help me with the numbers, rear end is stamped with wc115496. I believe the engine to be a WD engine which doesn't really matter but the number on the block is wd220972ga. Any info on these would be appreciated. Thanks
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2013 at 9:41pm
WC's and WD's ran the same engine. ....201 cubic inch and around 27-32hp. The year is 1942 according to your serial. I pull a 1945 WC.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2013 at 9:49pm
I knew they were both 201ci but is a WC block stamped with WD as the first two letters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2013 at 9:53pm
Where are you finding that stamp? I've got several and have never seen any stamping like that. Just casting codes but I could be wrong. Even if it were stamped and from a WD they were basically identical engines.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2013 at 10:06pm
On the left hand side between the carb and air cleaner. I'm just curious as to know if its not the original engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2013 at 7:30am
That engine is from a 49WD. Bookmark this page for further reference.
http://people.clemson.edu/~wsmth/SNFind/esn_tsn.htm
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2013 at 7:15am
The WC engines were stamped as WCXXXXXX and the WD engines were stamped as WDXXXXXX. You have a WD engine in your WC. Like stated above, both were 201 engines. Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2013 at 2:33pm
Ryan, all blocks should have a serial number stamped on em. The unstyled WC was stamped on the rear, center of the block and when they came out with a starter, it was moved to the left side of engine below and ahead of the air cleaner.
