as long as we're talking wd
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: as long as we're talking wd
    Posted: 10 Feb 2010 at 6:35pm
am i the only dumb SOB that always catches his gloves on the throttle lever on the wd?  i'm always knocking the throttle back when i turn the wheel to the left because my gloves catch the throttle and pushes it up...this has always been a pet peeve of mine with the wd.   alan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 6:53pm
I never had that happen, I did raise the disc once with Dads WD and slipped off the hyd handle and bumped the throttle open. That was the only time I ran a tractor into a fence, fence weren't no good anyway. Maybe you need to extend the steering shaft a little, giving you more room for hands and gloves.  I have a spinner knob on the wheel because the PS works great, guess that's what keeps my gloves away from the throttle lever..
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 7:45pm
I never had that problem.  I cant realy drive a WD or 45 due to the hand clutch. Iam 6'9 and I have to put my leg over the top of the hand clutch.  Its not good then I cant use the breaks.   kip
160 CA 920diesel 5020 HD-3
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:33pm
Kip, why don't you try bolting a heavy plate to the seat mounts at the bottom and extending the entire seat and suspension back? I have a friend that's 6'-7". He did something like that on his Farmall. Solved all the problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:37pm
Alan, maybe a little tweaking on the end of the throttle lever to bend it slightly forward might help? I have to do little things like that all the time to make the tractor more comfortable. I figure if i'm gonna spend a lot of time on there, I might as well be as comfy as I can. same goes for my work truck. I drive a lot, so I get things moved around where they "fit" right. Being uncomfortable or something being a nuisance like that gets old real fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 6:46am
ok, so the consensus is i'm a dumb SOB.  i can agree with that.  i guess its a good thing i left my mensa membership expire, so they don't find out and have to expel me!!  alan
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 7:24am
Alan, you need to get you a "necker's knob" on your steering wheel, that will solve your problem.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 7:27am
Alan, guess I wouldn't buy into the "dumb SOB" conclusion! Either that or you have a lot of company on here. I run into the "failure to see the obvious" more times than I'd like to think about....sometimes these challenges are pretty subtle, like the time I couldn't figure out why my WC was running rich no matter how I adjusted the carb. That was the time I discovered that the air cleaner was packed with dirt between the outer and inner walls....poor old girl couldn't breathe.
WC, CA, D14, WD45
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 6:17pm
well, I have the opposite problem as Kip, I'm too short an round, I'm always stretching for things.
Alan, I don't believe the conclusion was that you are the only dumb SOB. I can't work with gloves (never can find a pair to fit, short fingers for the size of the paw) so I wouldn't have that problem
Edited by LouSWPA - 11 Feb 2010 at 6:18pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 6:22pm
Alan, Do you have a after market wheel on the WD? Some of the ones I have looked at are set in to the levers a little bit. This might be why your gloves of hanging on the throttle lever. LOL
Don
