Tachometer and cable on D 17?
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: Tachometer and cable on D 17?
    Posted: 09 Feb 2010 at 8:35pm
mY D 17 didnt come with tach, I have one and was thinking about installing it on tractor , question is where does the tach cable plug into the tractor? it is a 59 with power steering and alternator (converted) thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 8:52pm
You can get an aftermarket tach with the white AC face for under $100 now.  The tach cable plugs into the back of the governor housing right under where the distributor mounts.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 9:21pm
If the tractor did not have a tach before, there would not be a fitting on the end of the distributor.  This is needed to run the tach.  I am looking for one for a 59 D14 is anyone has one.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2010 at 9:55pm
 pretty sure  I have one and a tach with cable I will check in the morning .
Mark in michigan
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 6:04am
I would like to find just the tach cable for a 59 D-17, any used ones out there?
Leon B MO
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 8:38am
I have a '59 D17 as well.  I bought a new cable and housing from AGCO last fall.  Ouch.  Cable and housing was I think $56.  You will need the threaded adapter and also the part that connects the square cable end to the slotted end of the governor shaft.
 I bought part of the fitting thingy that goes on the distributor from Norm last week, you might check with him, he may have more parts.  He also told me that you can use a keyed cable end instead of the square end, it eliminates one part.
Creek
