360 out of a 226 |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: 360 out of a 226Posted: 15 Oct 2013 at 7:31am |
How much stroke does a 226 take to get 360 cubes?
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
DrAllis
Posted: 15 Oct 2013 at 8:19am |
Bore of 4.630" and stroke of 5.375" gets you 362. Cannot stroke a 4 inch bore enough to get 360.
WildBill
Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
Posted: 15 Oct 2013 at 8:26am |
murphysmotorservice.com
go to murphys website and use his topic shop math.. pretty easy to use and find the math for cubes and rod lengths etc. !! Jeff is a good guy to deal with . i use his rockers on all my pullers !
good luck Charlie 175 !!
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
Charlie175
Posted: 15 Oct 2013 at 8:48am |
Thank you.
I must have heard wrong, I guess he said 260 which would be 4x5.25 Is this a common stroke? As you can tell I know little about stroking rods and such.
Charlie
WildBill
Posted: 15 Oct 2013 at 8:58am |
no replacement for displacement ! hee hee...
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 15 Oct 2013 at 9:05am |
I've put togather a few cheaper engines for guys at 4.155 bore and 4.28 bore and 5.4" stroke doe 295 and 310 cid. These engines don't require verry expensive parts and little machine work. Then I've put togather some pretty expensive ones with billet parts.
An offset ground crank and some Buda rods would get 4.85" stroke by the time the crank is cleaned up, with a 4.125 typical overbore sleeve would get a 260 cid engine. |
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1737 |
Posted: 15 Oct 2013 at 8:33pm |
I have 4.7 bore and 6 inch stroke in a 226 block
phil
