cluthces
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: cluthces
    Posted: 10 Oct 2013 at 8:47am
looking at parts dealers it says that a wd clutch is 10 inch in diameter with a 1 1/4 inch hub and 10 splines, if i found a clutch with those specs from say jegs or summitracing it would work right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 10:19am
ok, got in over my head lookin at clutches, whats the difference between spring, solid, and button clutches and which one works best
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 12:53pm
Button or 4 pad is the way to go. Less surface area but more surface pressure.
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2013 at 1:35pm
Spring center absorbs some stress when clutch engages, stops the shock load from transmitting . Solid center allows this shock but is less forgiving on any alignment problems as hub and disc are riveted to form one piece.
 Button clutch has a higher friction coefficient and is either engaged or disengaged and allows little or no slippage .
 I use them in my tractors, crawlers, heavy trucks, but one has to be careful also as they will wear pressure plate and flywheel faster if slipped that a fabric clutch will. When installing the flywheel should be refaced to clean ground surface first and same with clutch cover.
