D17 with 301
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 with 301
    Posted: 19 Sep 2013 at 9:35am
MattB sent me these pictures of his D17 with a 301 in it.
Looks great!
Matt, tell us about the conversion and what you had to do.
Charlie
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2013 at 9:43am
I cut a hole in the front bolster so crankpulley had room then put a hyd cylinder on front axle to push pull drag link for powersteering the back of the engine is all from a 180 which bolted right up. Had to grind a little out of the bellhousing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2013 at 9:58am
That is just cool. So I assume you are getting 70 or so HP out of it?
How does it pull?
I always thought of putting a 200 ci from a 6000 series in a 17 or 19.
Charlie
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2013 at 12:30pm
Tight fit. Looks good.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2013 at 10:00pm
Like that injection pump...more pics please... sure think thats neat.
Jamez99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamez99 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2013 at 2:32am
Thanks you  for updating us with this interesting information. you did very great job. keep it up
http://www.units.it/
http://www.free-braindumps.net/201-01-pdf.html
http://www.eccouncil.org/
http://www.ucla.edu/
http://en.wikipedia.org/wiki/EC-Council
https://www.facebook.com/ECCouncil
http://www.youtube.com/user/Apple
Edited by Jamez99 - 25 Aug 2014 at 7:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2013 at 7:15am
ive been pulling this tractor for about 5 years if u look close you can see the blocks purple that's a big al engine in there its susposed to have came out of an army truck
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2013 at 11:04am
That's real nice. Any videos of it pulling ?   Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2013 at 1:49pm
One of them purple people eater engines?
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2013 at 3:06pm
I SURE WOULD LIKE TO SEE MORE PICTURES OF THIS ANIMAL ! I THINK ITS COOL ! THERE IS LOTS OF RESERVE HORSEPOWER FOR A 301 !  I SEE IT HAS A SIMMS PUMP ON IT . THAT WAS A REAL EARLY 301 ... DOES IT HAVE THE PLATES AT EACH END OF THE CYLINDER HEAD ? YOU COULD PUT A TRICK 11MM A -PUMP ON IT AND SOME NICE INJECTORS THIS WOULD BE A NICE SLEEPER. I SUPPOSE THE CLASS WILL NOT ALLOW TURBO'S ? LOT OF POTENTIAL UNTIL THE DRIVELINE OR CLUTCH GIVES OUT.
IF YA CAN SOMEONE WAS ASKING FOR A VIDEO THAT BE REALLY NICE TO SEE
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 9:33am
Probably a hybrid gen set eng. the LH fuel pump block off has hole pipe plug and block off for RH oil cooler is different color.  Most of those were freeze plugs on early 2800's.
A natural asp 2800 with a Simms - I have never seen - but then they made a bunch of special apps for special orders.  IF it has the bubble in the front of the oil pan then is was not an early eng.   Fun trivial stuff
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 11:19am
Brad TeVelde has one in in D 17 puller narrow front. Pulls 5000 lbs and about 10 plus mph.
Work of art this thing is!!!
Neat stuff Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 2:28pm
Engine was originally turbocharged. Had oil cooler also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 2:31pm
Plate on the left front side of the block youcan see in the picture says it was specked for a mack truck.
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 10:28pm
What MACK truck had a 120 Hp engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2013 at 11:48pm
Thats what i was wondering!! Id hate to drive that thing ! I couldnt imagine any truck other than a pickup having a 301 in it
Edited by DougG - 22 Sep 2013 at 12:28am
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2013 at 8:00am
lotta old trucks had big al motors in em,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2013 at 9:50am
There was a bunch of info on the Big Al engines in the construction section recently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2013 at 10:32pm
Big Al was 844 cubic inches - a 25000 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2013 at 1:25am
There were 5 different versions of them,from 301-844 ci but the true Big Al was a 25000 series 844 ci
