pulling carb
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Topic: pulling carb
    Posted: 25 Aug 2013 at 6:04pm
what is a good carb for a WC puller 350 CI engine   and what kind of modifications do you make on them
Edited by patrickmull - 25 Aug 2013 at 6:09pm
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 6:30pm
 RPM range?
Romaninmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romaninmi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 6:31pm
I had good luck with a d17 carb with the plastic Venturi from a 175 a good agco dealer can get these yet I drilled out the main jet a small amount that fed 343 motor good never lacked fuel
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 6:38pm
we pull 4 mph 20% i talked to a fellow he said if you go to big you lose vacuum
Edited by patrickmull - 25 Aug 2013 at 6:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Romaninmi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 6:45pm
I never had a problem with that remember the stock carb is feeding 226 cubes you added over 100 cubes that takes more air more fuel to work good I am no expert but that set up worked good for me
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2013 at 6:50pm
also what gov housing and weight do you like and what do you do to mod them
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 8:23am
I am running a carb off an EIII Gleaner combine engine. I think it's a tsx 853, there isnt any fuel problems there. I need to do some work on the manifold and the carb. after each pull there will be a light frost around where they bolt togather, telling me..... There is a restriction??? I assume I am right, I too am a rookie, soaking in knowledge from the vets. on here.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 9:44am
My B frosts also!
Would like to know why.
Charlie
THE-MAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 1:36pm
MM 670 super with 1 1/16 -1.25 Venturi. That is a conservative recommendation btw
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 1:59pm
I wanna know how to get 350ci out of a 226! PM me with info if you care to share some insight.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 3:07pm
Big bore and stroke Benny!
The frosting is due to the venturi effect. Its normal.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 4:45pm
I've also had good luck with a MS 853 Gleaner carb...but I'm only feeding 240 cubes at 2100 RPM on my WC. I still think that this carb or a similar MS 454 off a WD45 or early D17 would be a good place to start. Send yours to Steve @ B&B and tell him what you're running, you'll get back a better than new looking sweet performing carb! Kip
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 5:47pm
4,3125"x 6" that is 350.55
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 7:13pm
 No one yet has mentioned a Zenith.  Any one using one and happy with it ?  I have always thought an M~S  was easier to service, easier to tune.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 7:32pm
i am using a zenith from a 44 MH and not happy at all that's why the post
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 7:52pm
What "The Man" said works fine. A 190 XT carb works great too with a modified intake manifold and electric fuel pump.
Juiceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Juiceman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 8:49pm
Are you guys getting 350ci with the 226 block? New to allis and have a wd45 id like to build for the 4000 and 4500. So any information will be appreciated. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 9:03pm
yes gleaner e
Hudsonator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 9:12pm
I always used brand new Zenith replacement carbs for an engine of about the same cubes stock as the one I was building.
Like "The Man" said, M670 Moline - 354 cid stock.
The brand new Zenith carbs have universal linkage - which makes them easy to adapt.
Then, you need to learn the hard way about jetting, air bleeds, emulsion tubes - like the rest of us did.  LOL
There isn't much a WC can't do.
WD's just do it better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2013 at 9:36pm
Thx Hudsonator .Look at it like this. I had Wi50 do some flow work for me when I first built my 327. The gleaner/45 carb flows about 100 cfm. The mm 670 super ( tsx 901) flows 125-135. Somewhere in there. Last time I looked that's 25% more. The gleaner e manifold is the superior choice, and it flows about 125 cfm STOCK. 125 cfm carb 125 cfm manifold...obviously it's " less wrong ."
Now, on my 327 that's 11 to 1, Barney cam @ 105, I still had to drill the main jet out. I would suggest about .025 smaller than your jet size. Otherwise it gets REALLY sensitive to adjust. My manifold will flow ALOT more than stock. The 901 is in my opinion a bit small IF I'm going to run over 1400 or so . I proved that on the dyno. I have not gotten a chance to finish my new carb. However I did build one out of a zenith that added over 12 hp at 1800 but l LosT 4 hp on the lowside. But I got the fix for that on my bench.
Edited by THE-MAN - 27 Aug 2013 at 8:19pm
jpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 4:17pm
Jack Coronett uses a g Moline carb on his 350 inch allis engines. Barney Taylor does also on his 392 cubic inch engines .Jt Richardson used a usx21 on his 392 inch engines and Mlpankey used one from 310 inches to 402 cubic inches. Jamey Sigmon with the yellow ca will back up JT Richardson using and recommending a usx 21 carb.
Edited by jpankey - 27 Aug 2013 at 4:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 8:31pm
U series. G, all the 283, 336 403 mm's had the same basic M-S body. The 670 super had the biggest Venturi. As I recall, after doing HOURS of testing for our own benefit, WI50 said the usx was a pooch on the bench. EVERY THING he has ever machined for me or information he has given me has been exactly perfect.... So I'm inclined to agree. Now the only larger carbs I have dealt with are the zenith military carbs. I Like them, alot. But you need some cubes or RPM to utilize one to it's fuller potential. Or an engine that will stay together for more than a run or two. OR an engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2013 at 11:15pm
My only hangup with M~S carbs is - where do you find small parts for them?
I'm having that problem with my farming Allis' - not to mention trying to modify an old carbs for pulling.  I accidentally found a brand new load needle and jet assembly for a 3020 JD M~S that fixed my 45 powered WD.  The ethanol content of modern gas is causing me to have to jet up - but I can't find new jets if I go too far with my step drills(ya know what I mean?).
So anybody with a good supplier of marvel small parts: like load assemblies, idle jets, emulsion tubes, etc - I would sure appreciate knowing about them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2013 at 5:54am
Other than what treadwell carb company In NY has, I constantly am
Buying cores at junkyards swap meets etc. I am completely ignorant on emulsion tubes   I HEARD of tweaking them, but I haven't had a chance to experiment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2013 at 6:31am
In my experience, the M/S carbs seem to perform a little better to around 300 cubes or a fuzz over, and allows you a little more room to modify. The trick with these updraft carbs is to increase air speed. Faster air speed with just the right fuel mix makes for some pretty nice torque curves on any cube engine. I have to say, with bigger cubes, those larger M/S TSX 901's, & 950's work out quite nice. The big toilet bowl Zeniths off the 190XT engines messaged over a smidge work nice on the big inch motors. The 464  carb off the WD45, and the 871 M/S with some mod's work real nice up into the 300 cubic inch range and gives you a little room to dial it in.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2013 at 9:54am
Read this. It's a little tough to read through someone's ignorance but there's some good information I took the time to post and don't need to again as far as air speed, how to figure venture size, and some carb modifications.
http://www.allischalmers.com/forum/forum_posts.asp?TID=65113&KW=speed+of+sound+mach&PN=2&title=carburetor-for-wc-puller
I'm not sure if that link works but search for a thread "carburetor for wc puller" by SuperM74.
Edited by wi50 - 28 Aug 2013 at 10:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2013 at 10:27am
Steve,
Can you get small parts for these carbs, M-S and Zenith?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2013 at 11:01am
I can't give specifics on fuel circuitry modifications on tractor carbs - because I haven't gone in depth with them.
All I can say is the new replacement zeniths have removable idle air bleeds than need to be tweaked - as most are too small.  So small they create an air-lock in the idle circuit that makes it behave more like a drinking straw (rich) than anything properly  emulsifying the fuel.  They'll fool you with an A/F meter, because they run rich when siphoning raw fuel (like sucking tea through a straw) - then lean out drasticly in short bursts when the circuit's signal collapses because it can't pull the un-emulsified liquid weight of the fuel (taking your mouth off the straw).
A screw up in your idle circuit will screw up the A/F all the way through the carb's function - as it has a huge bearing on the overall A/F ratio even when the main circuit is drawing.  To be honest, the majority of problems with fuel circuitry I've found are in the idle circuit - not the main circuit (Load circuit in a tractor carb).
I've done alot of tweaking on Harley-Linkert and Keihn carbs, Weber carbs, Carter 1 barrel B&B's, and early Carter AFB's that have the emulsion tubes attached to the boosters.  But, we're not dealing with any of those here - and I have not transferred what I've learned from them to give any advice on tractor carbs other than what I've stated on the zenith idle bleeds.
Now you know why I'm interested in small parts?  I actually need to get in depth on this issue to keep my old iron in the field with the bullcrap fuel blends being sold these days.  The variations in ethanol content have changed the properties of the circuits - and I need to fix that for myself - BADLY.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2013 at 5:07pm
a g Moline carb was on a 75 hp 402 ci I believe and if worked over will make 100 hp on dyno . the stock usx bolted on make 15 to 20 hp more on dyno . remember bernoulis principle fpr velocity to increase pressure decreases on front side of orifice/ venturi and pressure increases and velocity decreases on backside to push fluid motion through orifice/ venturi. the point where the fuel vaporizes is also where the heat is pulled from cause it takes heat to vaporize saturated vapor and frost can start due to the heat of air being absorbed down to the dew point. This frost can if builds thick enough reduce the orifice to a smaller size .
Edited by jpankey - 28 Aug 2013 at 5:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2013 at 7:03am
Hudsonator,
I have a lot of parts, most are stock replacement parts. Have parts cores, etc. A wall full of rebuild kits. The puller carbs I build are based on engine size. Most so far have been for under 300 cube engines. I like customizing the TSX464's and other large bore M/S carbs in that particular family of carburetors...
