allis swing cylinder
kansasbikerider View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kansasbikerider Quote  Post ReplyReply Direct Link To This Post Topic: allis swing cylinder
    Posted: 21 Aug 2013 at 2:43pm
needing a swing cylinder for a allis chalmers 816 b series 2 backhoe..called and checked every where a I can with no help.. anyone got one they wanna sell.. I can buy all the parts for a complete one but cost is way out there...understand there may be a case swing cylinder that may be the same specs,, I think its a case 580c but not sure..any help would be great thx Kelley 785 531 1141 or kansasbikerider@hometelco.net
agent008188 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote agent008188 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2013 at 6:28pm
I can rebuild your cylinder and help with parts. give me a ring 785-633-4377
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2013 at 6:58pm
Is it two cylinders mounted under hoe or is it a rotary piston like on the 615 hoe ?
MINNPAR should have the repair parts or if cylinders a hyd shop should be able to obtain generic parts for most repairs .
 IF they are missing - well good luck in trying to find original replacements
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2013 at 7:11pm
 I use KwikParts in Williamsson(burg) Missouri. They service Allis and Case, and get your stuff to you fast. They last got me the lift cyl packing for my 420 Backhoe, genuine CIH parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 10:37am
I think yesterday I saw a case 580 swing cyl on the web. Walt's Tractors, I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kansasbikerider Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 6:18pm
min par didn't have any thing but looking at all my options will try some of the places u all have posted thx for the help so far   it all helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote kansasbikerider Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 6:19pm
it is 2 cylinders the turion type
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 8:09pm
Dont know where in KS you are but i would try Ginder Hydraulic Salina KS can repair pretty much any hydraulic cylinder, they also fabricate cylinders for custom needs
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 9:41pm
  Sorry, that should have been Maine Tractor. Case part no. D36878. "580 swing cylinder" at 300$ Did you ever mention just what is wrong with your cylinder? Or is it missing?Confused
Edited by doctorcorey - 22 Aug 2013 at 9:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kansasbikerider Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 10:54pm
m y left hand cylinder was bent in the shaft and the last 3 - 4 inches is the vavle plate and spring called the cushioner and it broke there and ruined the whole cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote kansasbikerider Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2013 at 10:56pm
im only about 50 mile from ginder hydraulics   thought about hoff machine in salina   when I get the chance im taking both cylinders and let them take a look being one is still good
This page was generated in 0.432 seconds.
