pulling a 7000 series allis
timmypuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timmypuller Quote  Post ReplyReply Direct Link To This Post Topic: pulling a 7000 series allis
    Posted: 21 Jul 2013 at 4:40am
can you take a d21 210 or 220's transmissions and put in a 7000 series allis? don't know a lot about this series but only 1 that pulls in this area sounds like hell because howls so bad. i think its the power director trans making all the noise. found 7040 cheap brother thinking of buying and building into puller . power director trans is bad and we would rather just set it up like my d21 if possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 5:06am
Dont think that will work, 7000 series are totally different than 21,s,210+220 ;those things are so heavy to begin with, alot of stripping needs to happen; gutting the PD and run a straight thru shaft can be done to by pass that problem
Edited by DougG - 21 Jul 2013 at 5:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 8:27am
There is not one single part interchangebale in the driveline between a 7000 series and a D21.  The 7000 series driveline does not normally "howl", so there may be some custom made gears in it. It also could be a D21 chassis with 7000 series hoods.
