Finally ready to pull
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Finally ready to pull
    Posted: 14 Jul 2013 at 9:20pm
Finally got the D19 back together and ready for some local pulls.   I pulled the head off this spring as I knew last year that some of the valve guides were shot.   Ended up having valve guides replaced, new exhaust valves, and a couple intake valves, new springs and a couple seats had to be replaced. Interesting to find out that the rest of the engine looks in great shape like it was recently rebuilt but they didn't take the time to have the head fixed up right away.    Either way it is in much better shape now.    Took off my WD45 wheel weights as they looked funny in the center of a big 38" rim and put the D19 Rowe weights that I had in their place. Don't know what they weigh but other bathroom scale goes to 350 and they don't register on there.   Kind of a challenge mounting weights to a wheel that doesn't have the right bolt hole pattern without killing yourself.   Anyways, she's ready for Wednesday night so we will see what she does.   Pulled six times last year and got two thirds and one second so I'm hoping for a good puling season.   Here's some pics.
Edited by ChuckLuedtkeSEWI - 14 Jul 2013 at 9:22pm
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 6:08am
I like your Mid Mount weights, I have been looking at how to mount weights on my D17 like that.
Charlie
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 6:15am
  Chuck, it sounds like you are ready to full pull ! Good Luck.  Gary
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 11:24am
Ditto on the mid mount weight bracket...that's a great way to do it. I always like to see photos of other folks fabrication and engineering. Good luck Chuck! KipWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 8:57pm
I can't take credit for the weight brackets.   Chris(WI) sold all of them to me and he was the one who made them for his D19 when he pulled. I do like the way he did them and the rear brackets don't interfere with anything.   I could take off all the weights and immediately use the snap coupler lift arms and I wouldn't have to take off any of the brackets.
Gary my second place finish last year was 290 something and only 1.5 foot away from first and the sled weight was all the way forward. I lost to an international 686 that was all stripped down for pulling. Hope I nudge him out of the way this year.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2013 at 9:17pm
turn your front weights around,if they are under the 11 ft.rule.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2013 at 4:38pm
Mike some of the pulls around here won't let you hang weights more then 24" in front of the tractor casting so if I turn them around I am over that measurement.
cornbinder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cornbinder Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2013 at 6:39am
did you have the head milled to bump your compression up or do any port work?
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2013 at 10:06pm
Looking good Chuck!
