Dang new ones are spendy |
blue924.9
Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
Topic: Dang new ones are spendyPosted: 09 Jul 2013 at 4:28pm |
Was looking at a new carb that is bigger for the wd after we go through this winter, looking at new ones they are way too much, I have heard of drilling the stock ones out, but how big of drill bit is needed for a 240 cubic inch motor with a cam reground for stock or slightly higher rims? Or is there a cheaper way to get a new one, I have a marvel schebler on hand but was told it was smaller ( by pank I think so yeah) is that correct. Also how do you know how big to drill the stock carb out? Ps I was looking for carbs at Tony's tractors and they were 400 dollars and will a d17 carb fit, I know a wd 45 will
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90616 |
Posted: 09 Jul 2013 at 4:56pm |
The B- C carbs have a sleeve insert in the bore that can be removed and reamed oversize. I worked on a WC carb that also had a sleeve... Does the WD- WD45 carb have that ? Boring 1/16 oversize and a bigger main jet will get more air and fuel to the cylinder, if you got the rest of the motor ready for that !
blue924.9
Posted: 09 Jul 2013 at 5:19pm |
I have no clue if a wd and a wd 45 carb has that, the motor will be gone through this winter, just getting some parts lined up for it so I won't have to wait this winter
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 09 Jul 2013 at 5:27pm |
Call Steve @ B&B and he will fix you up. Just tell him what your doing and you will be good. He is an advertiser on here
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
blue924.9
Posted: 09 Jul 2013 at 5:41pm |
That is what I was thinking just wondering what you guys came up with
KGood
Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Posted: 09 Jul 2013 at 6:44pm |
We have used the carb from a 262 gasser. Some of them don't have an adjustable jet but you can get it in a rebuild kit. I think the carb on an XT is the same but has a bigger venture. It's a size bigger were the manifold and carb meet. Just match the hole or try to get to the same size. A 230 may have a bigger carb too.
