B Arched Axle, Narrow
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: B Arched Axle, Narrow
    Posted: 26 Jan 2010 at 1:13pm
I have a B arched axle that is 6 inches narrower than standard. 30 1/2 inches spindle center to center. May be homemade but can't think of a reason why anyone would narrow one unless he was building a Potato B. It came off a 38B parts tractor. If anyone is interested contact me. I have no use for a narrowed B arched axle.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 4:03pm
Huh?  I would definately look at that one a little closer to see if there is any evidence of modification.... Since the Potato B has always been describe in the lit as the straight adj axle, (although slightly narrower) your piece would be an interesting conversation piece.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 4:56pm
   It couldn't be bent in, could it?
http://www.rumelyallis.com
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:33pm
Ken, I am in Texas right now, wish I could stop by and put an eyeball on that one. Texas is BIG though, and I won't be anywhere near your place. I'm on South Padre right now, be headed up through Dallas into OK/MO on Friday. Your corner of the state includes traveling through Houston and too many miles of back roads for us traveling in the coach. I have to believe that axle was modified after the factory, but I sure would like to see it.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 7:37pm
Can you post a pic?
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2010 at 8:23pm
Brad
    Whoever narrowed it up did a super neat job of welding it back together. About 3 inches were cut out of both sides of the top of the arch on both sides of the squareish center. Except for the welds. Just looking at it, it's hard to tell it has been modified.  The V going back to the rear pivot had to be pulled together at the wide ends too. I will try to get a good picture tomorrow in the daylight and post it.
  Brad. I'm just  south of I20. 120 miles due east of Dallas.
  Arcadia Pop 320. right on the Lake MI. Short for Michigan  If I was heading to Muskegon, Michigan from here or from  Dallas I would go 30 and 40, 55 and 57 to Chi-caw-go-ski and avoid the Oklahoma turnpikes.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:13am
Know that path well except I jump off on 70 go to Indy and then 69 North.
Now when you get to the 55 /57 get off you need to do one exit north on 55 and get off. Take a left at the stop and go about a half mile or so to Lamburts for an eating treat.
Don't bother to thank me know there will be time after you recover. Unless your a glutton you will have take homes also.
I never miss it when passing thru there. Dixie and I smile for two days after.
Edited by Dick L - 27 Jan 2010 at 11:19am
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:04pm
I have a very similar B (1938) - probably 6" narrow.  It is rumored to have been brought up to MN from TX in 2003 or so.  Welding is very nice on front end, but camber is a little off.  I am looking a photo...
Really obvious since the tie rod ends are fully turned in to get proper toe-in.  Never figured out what the purpose was.
kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:15pm
This is realy getting interesting. This 38B is a Texas B. On this one the tie rod is shortened and welded back together in the center. I will get a picture of it posted soon.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 7:00pm
Anything to do with any special row spacing for special crops down there in texas? Do you guys grow strawberries or anything else with weird spacing down there?
