Oil Pan Removal on a 170
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: Oil Pan Removal on a 170
    Posted: 24 Jan 2010 at 9:06pm
I just picked up a 170 gas that has thrown a rod through the side of the pan. Can I drop the pan without removing the wishbone and front assembly? Trying to get a look at what I am in for. What else used the 226 engine besides the D17?
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 9:09pm
The Gleaner E engine is the same and so is the 175 gas.  The WD45 used a 226 but it was a lighter block.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 9:57pm
It's pretty easy to remove the axle, then you will be able to access the pan with no problems.
