9 bolt hubs -Int. to AC D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 9 bolt hubs -Int. to AC D21
    Posted: 23 Jan 2010 at 5:04pm
Will a 9 bolt hub for pressed steel wheels of a 1066 Int. with 3.25 axles work on a D21? The axles are the same but is it keyed the same ?
Eric NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 5:28pm
Doug, The keyway in the axle is entirely different on a 1066.....almost a double type keyway. Eric NY
JK(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 5:40pm
 IH won't work, but older 9 bolt JD and Case share the same keyway.  I looked all over for my two-ten and found a set off of a 4320 JD I believe. They worked great. Good luck.
jeffnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffnil Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 6:43pm
I have a set of nine bolt hubs off of a 210 if interested
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 7:27pm
A custom made key is  the answer to fitting a 3.250 Dia. hub of a different Mfg. to a D-21 axle. I've done this with Massy 32" wheel center castings on a D-21. I would be able to make most any cross section key required.  (262) 719 3552  Dale
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 7:41pm
I used Massey 44 9 bolt hubs on a D-19. The keyways were different but that was solved with a special machined key.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 10:08pm
210 hubs won't work, the have a 3-5/8 axle.
