d17 226 gas/170 226 gas points/ignition assembly ?
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: d17 226 gas/170 226 gas points/ignition assembly ?
    Posted: 23 Jan 2010 at 2:18pm
I am replacing the engine in my 1959 D 17 with a 226 gas from a 170 AC, the problem is the points/ timing assembly is I think the same but the dowl pin doesnt line up on the 170 block with the assembly from the d 17 engine. I am just taking the parts off the d 17 226 and puting them on to the 170 226 . what should I do. Can I use just tap out the dowl pin and bolt it on or will that do damage to the timing gear, or do I need a different timing points assembly . If anyone would have some knowlede on this please let me know thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 2:28pm
It is maybe more commonly known as the governor assembly, the points are mounted on to it hope this helps. thanks
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 3:55pm
Why don't you want to use the governor assy that's on the 170?
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 7:04pm
I bought the block and head together as one unit but BARE everything had been stripped.
