Carburetor
Kris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kris Quote  Post ReplyReply Direct Link To This Post Topic: Carburetor
    Posted: 14 May 2013 at 7:16pm
Hello all, I am rebuilding a zenith carburetor off of a 190. The problem I am having is that I will not be putting the carb on the tractor for a while (1 month or so) and it seems like when I get it cleaned up the thing rusts inside very quickly. If I was going to put it back on the tractor immediately I wouldn't worry about it, but I don't want rust in the system. Any ideas what I could put on it to keep it from rusting that would be ok to run when I an ready to use it?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2013 at 7:21pm
  COAT IT WITH PNETRATING OIL WILL HELP
Kris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kris Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2013 at 7:25pm
Ok thanks. I read somewhere to coat with wd-40 then seal it in a ziplock bag. Guess I will try it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2013 at 8:16pm
I use a 50:50 mix of WD40 and light oil in a spray bottle on my parts that I don't want to rust and are in out of the weather.  Seems to be good for several years with no rust problems.  I'm in the somewhat humid midwest too.
