My AC170XT
chadsma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chadsma Quote  Post ReplyReply Direct Link To This Post Topic: My AC170XT
    Posted: 03 May 2013 at 10:13am
Here are a couple photos of my 170XT.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 10:23am
Never heard of one. Never saw one with those black stripes either. Learn something every day! Good looking unit!
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 10:40am
Is that a 433 from a 6080? Looks great in there.
Steve
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 10:52am
NOW THAT is how they should have came from AC! VERY COOL!
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 12:07pm
that is pretty nice . Hope you turned it down some. That's a lot of power for that drive line
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 2:09pm
That's really nice :D ive never seen the fenders black before.
There are no atheist in foxholes.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 4:04pm
Great looking 170xt!  Did you use a 433T or 433I engine?  I'm guessing you used a gleaner K2 433T?  Was it very difficult to marry up the clutch/transmission housing bolts?  Did you use the existing front hydraulic pump on tractor or use an engine driven hydraulic pump mounted on left side of front plate?  Are your rear tires 30"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chadsma Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 8:09pm
motor is out of a combine and is turbo and intercooled. had to make a spacer plate because clutch shaft was 1.75 too long  and I used a 190 flywheel and clutch. had to make a new adapter for front pump. alternator moved to right side. used 180 water pump housing. tires are 18.4 28.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 8:17pm
Nice. What kind of road speed you got now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chadsma Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 8:40pm
The motor is out of a combine and it is turbo intercooled. I had to make a spacer plate cuz the clutch shaft was 1-3/4" too long. I made an adapter for the front hydraulic pump and used a 190 fly wheel and clutch. It has a 180 water pump housing and a 60/80 exhaust manifold. It has 18.4 28 tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chadsma Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 8:41pm
The road speed is about the same as it was before the modify.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 10:40pm
That's what I need in this guy.....the tall front spindles and 18.4 x 34's make it one nice riding tractor....that engine would be sweet in it!
ALLIS EXPRESS!
This year:
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2013 at 11:09pm
I agree with Injection Pump Ed, "NOW THAT is how they should have came from AC! VERY COOL! " Yes, very cool indeed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2013 at 8:20am
From viewing the changed color of the chrome exhaust stack, I imagine you have put it under load to see how it compares for pulling??  Was the original engine a 226 gas or 248 perkins?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chadsma Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2013 at 9:24am
226 gas and it was very under powered
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 7:18am
Nice looking tractor. I know you guys put a lot work in to it.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 7:30am
Pretty cool -- interesting setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 9:13am
A model 170 with 16.9 x 28 rear tires at 2,000 rpm does 15 mph...........at 2400 rpm it would do 18 mph............18.4 x 28's would be more than that.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 9:32am
Nice install! Looks like it came from the factory that way. Have you had her on a dyno yet, if so what HP did it show?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2013 at 9:48am
Flywheel was 95 HP, so PTO should be around 83 HP at 2,200 RPM (725 RPM PTO speed).
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 10:16pm
Cool
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 7:25pm
Good Looking set up. I can't quit chuckling at the comment about it being underpowered before with the 226 gas. My guess is you have twice the torque if not three times as much as the gas. You probably do notice it being a little more power. rw
