Where does the CA Carb Link Spring go?
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Where does the CA Carb Link Spring go?
    Posted: 20 Jan 2010 at 4:46pm
could someone post a picture. I purchase one for my CA and I don't know where to hook it to. I know it goes in the hole on the linkage itself...but there does it connect on the other end?
"Better By Design"
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 7:11pm
Here's a picture. It looks like it attaches to the manifold bolt. Good luck!
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 8:20am
Yep; attaches to the top manifold bolt; large loop over the manifold bolt, small loop thru the throttle rod. I use a piece of heavy wire (coat hanger wire) with a hook on one end and insert it between the block and manifold to pull the spring up over the manifold bolt (after attaching the small loop to the throttle rod such that the opening in the large loop faces forward).
This page was generated in 0.127 seconds.
