201 / 226 governor springs
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: 201 / 226 governor springs
    Posted: 20 Jan 2010 at 3:36pm
 Taking apart an engine and the governor spring has a yellow stripe painted on it , who can tell me what  rpm range this spring was intended for and what other colors did Allis use and what were their rated speeds  ?  Thanks, Gary
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 3:42pm
A d17 and 175 spring have blue stripe .They say they are a different shade but it takes the partnumber for me to know the dfference. I think white is a wd spring . I dont know the yellow spring so I guess it would be a wc then again someone could correct me cause I may have the white spring confussed . GLeanor spring has no stripe or  slug in the center of the spring.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2010 at 4:16pm
I got grease on the new one and couldnt tell what paint color it was. I had a wd45 and a d17 new. I used the grased one because it had larger wire and a thicker plungr than the yellow strype one. If I'm rightthe yellow is for wd45 and wd/1700rpm mag.
