What a mess! 7010 PD Tranny
roscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Topic: What a mess! 7010 PD Tranny
    Posted: 18 Jan 2010 at 11:44am
Why didn't they put a drain plug on the suction screen cover of the 7010 power director tranny?  !!
Most of the oil is drained from the transmission at this spot (less than half from the drain-plug), and when you break that thing loose - hello shower!
Since I had it off, I drilled the plate and welded on a 1/2" NF nut, and installed a drain-pan plug.  You don't have to do this very often, but having a plug will sure make we want to do it again.
- Rocoe.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 6:07pm
Removing the 3/8 bolt first with the copper washer will do the same thing, might take overnight for all the fluid to drain down. You should always remove the plate and clean the pump intake screen also. HTH, Mike
