7000 series pulling tractor
super allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote super allis Quote  Post ReplyReply Direct Link To This Post Topic: 7000 series pulling tractor
    Posted: 21 Mar 2013 at 9:12pm
wat would be the best route for a clutch to hold up in a 7045
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 9:35pm
It depends completely on how much horsepower you plan on making. Need More information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote super allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2013 at 9:34am
its probably pushing around 8-900 rite now not really for sure but in that ball park,, clutch hub is shearing the teeth off, puling in  a 12,500 and 14,000 open class, everything stock pretty well besides the motor
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2013 at 9:42am
You aint from Effingham your from Green creek.
                         IG
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2013 at 5:27pm
What have you got done to this tractor? WHat pump, injectors, turbo or turbo's? We need pics! lol Love to see it.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2013 at 6:12pm
The torque limiter hub on the flywheel?? or one of the two internal Power Director hubs ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote super allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 12:06am
The power director hub shears off can't slip it like you could a triple disk so it takes a lot to just get it started torque limiter is bolted solid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 6:06am
I'm too stupid to figure out what you are failing????????? How about the splines inside of the low range clutch housing???....I've never seen any "hub" fail as you describe it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 10:05pm
I would guess he is talking about the teeth on the clutch discs.   MACK
