tire size selection
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: tire size selection
    Posted: 20 Jan 2013 at 1:23pm
Well i know alot of people prefer to ditch the smaller rims that cam factory and go with  38 in with, lets say a 14.9 or 15.5 tire. Fro m this i here allis' tend to do very well. But i remember growing up in the 80's and early 90's seeing people run a shorter and fatter tire, well around here anyways. So i guess my questoin is, i run (depending what track im on) either a 16.9-28 or 14.9. I found a set of 18.4-26 that i would like to purchase cuz of the good deal i can get on them and wondering if these would be any good for the 4 mph 20% over rpm class i want to get into? As for now i have my wd45 set up for a 3.5 mph 10% over class with 16.9-28!
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2013 at 10:41pm
sad to say around hear it's the width not the height that matters
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 6:16am
so wider would be better?
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 6:56am
Seems everyone restricts width, on a good track a narrow tall tire will apply more traction than a wide tire. You get a long foot print with 38" tires. I have looked at lots of tires, I want to move up, but to gain the footprint nothing short of 38" will help much. I am running 16.9x26 on a WD and they work perfect in the 4 mph. The tractor runs 3.8 to 3.9 wide open, you never have to wory about the horn. With the 18.4, it could be done with practice.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 11:17am
 FYI, a 16.9X28 Firestone bias tire is 56" in diameter.  A 18.4X26 Firestone bias tire is
  57.4 " in diameter. Your ground speed  with either tire is essentialy the same.  Your flat plate  dimension will rise from 209 sq. in. to 242 sq. in.  To gain that footprint with a 38" tire you would have to step up to a  16.9X39 with 252sq. in. and a  66.3 in . diameter.
   Even a 14.9X38 is 64" tall with only 200sq. in . of footprint.
 I ran 16.9X26 Firestone 151 on the D17, old, hard and sharp . 38's would have gained me nothing. My .02
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 12:29pm
Well it depends on the rules. For instance some rules say nothing bigger than a 15.5 up to 5500 lbs. So in that case a 16.9 or 18.4 26 is a hinderence . When you have 16.9 or 18.4 26 in the same classes as 16.9 38 or18.4 38 s the winners 38s plus i never seen a rule against widening the rims to reduce height.
Edited by mlpankey - 21 Jan 2013 at 12:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 12:35pm
all good advice, but what im looking for out of the shorter tire is to keep my rpm up higher in the 4 mph 20% over rpm class where as with 38s i would have to lower my rpm to compensate for the 4mph rule! Also with the 18.4 26 i figured with the width i have more tire on the ground instead of running the 16.9 28s which would have less. thats what im thinking but if im wrong please correct me
EricSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2013 at 5:40pm
I've always why no one runs the 30 or 32 inch tires should be cheap to buy used ones and I know caseih and a few others use 8 bolt centers I've been wanting to go to a salvage yard myself some day
This page was generated in 0.114 seconds.
