steering clutches on hd4
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Topic: steering clutches on hd4
    Posted: 14 Dec 2012 at 7:38pm
I HAVE A QUESTION ABOUT HD4 STEERING CLUTCHES. THE PICTURES IN BOOKS ARE BLURRY AND I NEED TO MAKE SURE OF THIS . WHEN TIGHTENING THE 6 BOLTS FOR FINAL ASSEMBLY. THE SPRING LOADED FACE PLATE LEGS SHOULD MAKE CONTACT WITH THE BRAKE DRUM AND THEN A TORQUE OF 25 LBS ON EACH BOLT IS WHAT I UNDERSTAND FROM BOOK. AFTER THAT THE ADJUSTMENTS ON THE THREE CLUTCH LEVERS TO GIVE THE 2 1/8 INCH DISTANCE FROM LAST CLUTCH RING TO WHERE CONTACT IS MADE ON THE THREE FINGERS. IS THIS CORRECT FOR ASSEMBLY ? THANKS RANDAL
This page was generated in 0.275 seconds.
