ditch witch v30 crowd lever? |
Mrgoodwrench
Joined: 03 Apr 2011 Location: CHICORA PA Points: 2095 |
Topic: ditch witch v30 crowd lever?Posted: 27 Nov 2012 at 9:05pm |
last winter we picked up a v30 for the farm. seems to work good haven't used it too much. there it a hyd lever labled "crowd" but it doesn't seem to do anything. does anyone know what this is for?
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Allen Dilg
Posted: 27 Nov 2012 at 10:15pm |
Hello Mr Goodwrench Haven't worked on any trenchers in a very long time Creep and crowd should be the same. There should be a hyd flow control valve in that line that adjusts crowd speed, and the crowd lever to start and stop movement also it should reverse direction. Good Luck
Mrgoodwrench
Posted: 27 Nov 2012 at 10:22pm |
i assume you mean reverse the cutter ...i thought that but it must not work...guess i need a operators manual
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42202 |
Posted: 28 Nov 2012 at 9:55am |
http://ditchwitchv30.informationconcerning.com/
