hd6g clutch
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Topic: hd6g clutch
    Posted: 09 Nov 2012 at 4:51pm
I went and started moving some dirt around with my 6g this afternoon and the master clutch went out i have never messed with it. how hard is it to fix and what parts do i need its got a oil clutch . where do i get them at i know my dad got parts through a napa store years ago for it he said it was much cheaper than fiat.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2012 at 8:44am
are you sure it is gone and not just an adjustment or low on oil? i have never messed with an oil clutch but would think there is some adjustment. good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2012 at 8:07am
its the clutch i had it adjusted about a year ago and the mechanic said the disk was about gone .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2012 at 2:18pm
The oil clutches are a multiple disc clutch like your steering clutches. They are rather expensive to fix. I just priced out the steel and fiber disc's for a customer and they were right around $2000.00 for all the disc's.    Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2012 at 2:29pm
ouchOuch
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2012 at 2:36pm
When replacing multilpe disk clutches you usually don't have to replace all of them.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 3:36am
The hd6g master cluch should have a dry cluch AUBURN or ROCKFORD
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 4:17pm
sound like a good project to do in the spring .
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 4:25pm
i just went and bought a new oil filter and change it and see if it does anything
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2012 at 4:48pm
What is the s/n of your HD6? Does it have a 2 piece hood?
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 8:08am
the ser number is hd6g 22589  now if im not mistaken my dad changed the rear end out im not sure i know thats the 2 engine in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 8:10am
I do remember the trans went out back in the 80s and he took another trans out of a ligh lift and the bottom of the case was a little different so they had to chang the guts out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 8:13am
i changed the oil filter out yesterday afternoon and its moving again i brought it back to the shop and ill check it out to see if its the pump or what it might be getting hot and stopping i drove it about 15 min and it worked fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 8:50am
I am interested to find out more about your oil clutch repair. My HD6G is older with the Auburn dry clutch. I often thought that having an oil clutch would be the end of clutch problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 10:25am
ok i ran it for over an hour and no problems i gues the filter was stoped up . dozer i do know several other times that the clutch as went out when dad used it everyday loading trucks he sold the loader back in 86 and i bought it back in 96 the guy who had it said he replaced the master clutch in it but it spends it days now under the shed  unless i need to move stuff around . that machine has ALWAYS been bad on the right steering clutch until i got it and had the matalic disk put in it . dad paid 18500 for it new sold it for 6500 and i bought it back for 3000 because the right steering clutch was out .
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2012 at 10:32am
dad had a shop full of parts he bought 3 parts 6gs at a sale  and dismantled them and after he died my know it all mother sold the whole works for 600.00 and what was left her and my  know it all step brother  sold the rest for scrap at a dollar a hundred .
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2012 at 1:52pm
well i ran the ole girl for about 4 hours yesterday no clutch problems i guess the filter may have colapsed or just stopped up not letting oil through I plan on putting her in the shop for full maintance soon .
