powershift rebuild
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: powershift rebuild
    Posted: 01 Sep 2012 at 3:00pm
Any one know how much it will cost for a 1976 7060? No labor just parts thanks
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 4:12pm
The gasket set is around $425.00.That includes all the gaskets,O-rings,sealing rings for the clutch packs,new stake nuts for the shafts,and assorted other goodies to do the job.The friction discs are around $125.00 a piece.Usually the discs last a long time.The teeth inside the discs can get partially sheared or sharp.If you don't need any hard parts (housings,gears,castings) they are not super expensive to work on.The special tools and a service manual are certainly a plus to have if you are going to do it yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 4:58pm
Alright thanks how many friction disks are there?
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 7:31pm
We did ours about 2 years ago and it was about $2000 for all the rubber parts and springs that separate the clutches. Ours had the threaded neck broken off of the front clutch hub. that part new was 2500 or so. If I were you I'd have that part magna-fluxed before I put it together.
RW
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 7:33pm
I believe we put all new clutches in too. RW
This page was generated in 0.031 seconds.
