WD45 battery ground bolt
Manure Queen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Topic: WD45 battery ground bolt
    Posted: 27 Aug 2012 at 6:01pm
Just brought home a WD45 in remarkably good condition and am in the process replacing 6 V battery and box.  The old ground bolt  to the right as you face the rear
had been sheared off likely from corrosion and someone had run the ground to the same bolt on the opposite side via cable.  I tried to pull the old bolt with heat, penetrating oil and an easy out, only to shear the easy out.  It's an inch long and ends blindly.  I prefer the location of this ground as the box is set up for the ground strap to exit cleanly.  I suspect my only option is to drill and tap it, or run the strap to the other bolt on the left.  Anyone else encounter this or have a better plan?  Small thing, I know, but frustrating.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 7:59pm
I went through the Dick L school of broken bolt removal and it didn't call for an easyout. Use a center punch and try to start a hole dead center and drill perfectly straight with a small bit and graduate larger as needed. Don't be in a hurry. Clean the threads with a tap and a seal pic. If it's a blind hole mark the bit so you don't go to deep. remove anything that will hinder keeping the drill square to your work. Be patient and get er dunn. If ya leave it it'll drive ya crazy.
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 8:23pm
problem is when you bury an easy out in there, it's harder than any drill you're likely to have.
only remedy that has worked for me was to drill small holes all around the broken e/o until it can be pried out with a probe (like a small screwdriver).  i'll definitely follow this thread though to see if there's an easier way,,,!
btw i've also spent a few small rotary tool grinder tips doing this surgery. no fun that way either.
Edited by CAdon - 27 Aug 2012 at 8:24pm
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 9:03pm
Believe me, I'm wishing like hell I never fell for the easyout -- too good to be true.  The sad thing is, the old bolt drilled pretty easily with a good bit. Think there's a snowball's chance I can drill it with the easyout embedded for an extra skill test?  I weigh 120 pounds.  I think I'm going to ask my brawny friend who's an excellent metal man.  You're completely right -- if I leave it (which is what everyone else has done)  it will drive me crazy.  I thought about it all day today...  that's when I knew I should turn to the forum.  Thank you for your advice.  Where's Dick L when I need him?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 11:11pm
How about welding a bolt head onto what you have there and then heating and trying to get it out?  When I have tried this, I have always had good luck turning the old rusty bolt IN more at first and then backing it out.  Just a thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 11:32pm
Very clever idea.  I'll run it past my welder pal.  I have to take some work to him this week and I'll bet I can talk him into having a look.  I'm sure any other sane person would just connect the ground to the opposite bolt and forget about it but this is driving me nuts.  I really appreciate the comments.  You guys are the best.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 11:42pm
I just had to deal with a sheared off bolt with a broken "easy out" in it last week.  I welded a washer on to the broken stub of easy out and bolt and then welded a nut to that. I melted some parafin wax into it while it was still hot. After letting it cool right off, it screwed right out.
This was a 1/2 inch stud in a 1 inch thick casting.
Edited by Alberta Phil - 27 Aug 2012 at 11:43pm
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 5:30am
if you can drill a hole in a piece of thin flat strap weld it to the easy out  you then have a handle to turn i do this on broke bolts also it puts heat in the bolt and expands it so let it cool before you try to remove it
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 6:51am
I have done the welding a nut on it before. You may have to do it a couple of times but it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 11:43am
Here's the miserable part...  The broken bolt and the sheared, embedded easy out are flush with the frame of the tractor.  I suppose if my welder places a washer center over the offending bolt end, he'll have a little to weld to but not much.  I hope he can get decent contact.  Welding the nut is much more straightforward.  I like this plan as it stands a chance of preserving the threads.
Time for the prayer hotline...  That, and I will write "I will never use an easyout again" one hundred times.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 12:04pm
A carbide burr in a die grinder will eat a tap/easy out.
If your handy with the gas axe you can blow out the broken easy out with the torch
1968 D15D,1962 D19D
Mochaman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mochaman Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2012 at 9:31pm
Right here is your answer in my opinion, the carbide burr that is. We have done it this way for years....it works. Then you can bolt a drill guide on with the proper sized bushing and drill out the broken bolt.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2012 at 4:55am
on my wd the ground wire is just under were the amp gauge is. there are 2 bolts the front one (when facing the battery box on the L.side of the tractor) is were my ground wire goes, couldn't ya use the back bolt to put the ground wire or is mine set up wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 11:25am
I appreciate the advice.  I had my welder take a look at it who agreed that a carbide bit may be the best option.  He then spoke with the machinists 2 doors down from him who would prefer to clamp it down in their shop vs. doing this freehand.  That means I'd have to pull the top of the gearbox as the battery ground is contained within, that also would entail unbolting the steering shaft and removing the gearshift.  This seems a little involved.  Do you you guys freehand it with the carbide bit?  Remember, it has that embedded easyout (which I will never, ever attempt again).
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 11:44am
If you have an air compressor, a cheap air grinder with a carbide burr will grind the easy out away. If it was mine, and I have the carbide and air grinder, I would weld a washer to the offending bolt and then weld a nut to the washer and back the whole works right out. Been there done that.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 3:15pm
I would weld the nut on,  do the grinder deal, or reattach the ground to a different spot and find a new welder! Or better yet learn to weld because you will need to weld again. Just my thoughts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manure Queen Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 4:06pm
Roger that, mdm1.  Lost 2 welders, a good mechanic and a shop full of tools in 2010, but I kept the farm.  All in all, I'm lucky.  Trust me, I'll get this bolt out.  Just wanted ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 11:28pm
I have removed many broken bolts/studs by welding directly on offending culprit and slowly buiding up the height untill I can get a vise grip on it and turn it out.This requires many arcs/puddles and sl*g chipping to build it up but the constant chippng and heating seem to aid in loosening.Many offenders are broke about a thread below flush but I have won every battle.Some required a "start over" after twisting off the "build up" but that's just the way it goes. I don't seem to be able to weld a little nut on the inside to anything....the sl*g gets me every time.( No wire welder around here)
Edited by SteveM C/IL - 07 Sep 2012 at 11:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 11:31pm
why is my "a" in "sl*g" a star looking thing? I edited out but it put it back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 11:32pm
WTF!! Done it again!
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:11am
With the hole drilled into the center of the bolt, providing the easy out is broken below the surface of the hole, I would take a wire welder and weld the hole full. Then weld the washer on. By welding the hole shut, you have made the entire bolt red hot, which has expanded and contracted the bolt , which will break it loose. Then after you weld the washer on, use the candle trick , you should be able to turn it out with a pair of pliers.   Dave.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:52am
Steve, just testing to see if sl*g is doing it from my computer as well.
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:52am
I know it's to late for this to be used, has any one ever used left handed drill bits? When you drill with these it will naturally want to make the bolt come out. http://www.sears.com/hanson-5-piece-cobalt-left-handed-drill-bit-set/p-00919883000P
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 4:54am
There's your answer Steve. For some reason this program things there is something wrong with the word sl ag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 12:02pm
 If you weld a washer on first, you can weld the nut on the outside to the washer. Just leave enough of the nut to get a wrench on.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 1:58pm
I have a set of left hand drill bits and haven't had much luck. Although I have had the good  fortune  to not have to use them often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 9:50pm
If a bolt broke off while trying to back it out of a rusted hole, the left hand bits won't do much good. And if they need sharpening, well I can hand sharpen any drill cept a lefty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:17am
Charlie, you just gotta stand on the back side of the grinder for those lefties.  LOL  Evil Smile
Edited by Ted J - 09 Sep 2012 at 7:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:04am
I am a lefty, How could that drill bit going opposite not work on removing that bolt, righty tighty, lefty loosey? one of my friends swore by this for getting broken of manifold studs out of a block.
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:34am
Because, usually the "stick" of the rust is stronger than the bite of the drill bit.
