Series III D17D Hyd Arms
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Series III D17D Hyd Arms
    Posted: 16 Aug 2012 at 7:30am
wont go down. I have a long pipe on them and still cant get them to move. I tried to do a search on this topic, but cant seem to find anything. The lever on the steering column is moving alright. Do the three levers by the left fender have anything to do with the hyd arms or just the remotes. If I can get them working I might trade it for a 70 Buick Electra 225 that came from Kansas.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 7:55am
Holding forward on out side control should do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 7:57am
One of the three levers on your left (when sitting in the seat) needs to be held downward for the valve stack you're using.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 5:19pm
I left the 12ft piece of 2" square tubing hanging on the 3ph arm last night. It was in the down postion this morning. I will see if it comes back up after I get the loader hose repaired.
