Sealing F2 variable speed drive
ScottinSWIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottinSWIL Quote  Post ReplyReply Direct Link To This Post Topic: Sealing F2 variable speed drive
    Posted: 13 Aug 2012 at 9:21pm
  Can someone give me the best way to go about removing the large nut on the variable speed on a gear drive F2.  I'm mainly wandering about what the best way is to secure the shaft from turning without damaging anything.  I realize a large impact would probably do the trick, but I do not have one avaliable at the moment.  To be clear I am talking about the variable speed for the tranmission.  I have the two large O-rings on hand as well as wanting to update the fitting that the oil line attaches to.  Thanks
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 4:08am
big pipe wrench.  When I did the K2 it wasn't exceptionally tight.  The vvar speed drive bearings were the achilles heel on the K2 for me.
