b/c rear wheel question
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: b/c rear wheel question
    Posted: 31 Jul 2012 at 3:22pm
I have a b and a c and both of them the rear wheels will not tighten up. Are the clamps the same for the four bump and the single rib?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 3:47pm
Not the same. Two with a straight bolt that go next to each other. Then two with eccentrics which go across from the straight ones to tighten against the straight bolt clamps.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 4:54pm
If it won't tighten you can use shim stock, or go with 4 (four) eccentrics.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 4:57pm
go ahead and use shim stock but do not use four eccentric clamps the clap that is in the driver lugs must be a solid clamp. If you put a eccentric on the drive lug it will loosten when enough power is applied.
Tim in arkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 6:35pm
Having the same trouble  with my 1938 B   was at tour local show back in June and had the left wheel fall  off   twice   one was during the parade to the downtown area needless to say I am working on it now
Allis Chalmers fan from Arkansas
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 6:39pm
Unless you're a purest doing a restoration, the four lug rims similar to those found on a Farmall A are mechanically superior. The wheel clamps on these tractors was not one of the better ideas that came out of West Allis.
are genuine." - Mark Twain
bitburn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitburn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 7:57pm
When you say wheel fell off, do you mean the actual tractor hub hit the ground.  That sounds really scary.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 10:04pm
Take a straight lock and a cam lock and put the cam lock on top of the straight lock and insert the cam lock bolt. Now turn the bolt so the cam is fully extended. now note the difference. Use shims to tighten your wheels. Good tight wheels with the locks are every bit as solid as loop wheels and look a whole lot better. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 4:51pm
I wonder if I could weld these up so that there is more material. I tried shim stock and it worked its way loose. I really need to fix this problem. The B isn't too bad. The c is getting dangerous.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 5:21pm
Do not weld on a rim with a tire mounted it can EXPLOE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 10:06pm
I use 18 or 20 gauge sheet metal for my shims and cut it a bit long, then bend the ends over so it can't move around. You can weld the shim to the wheel lock, but I believe they are made of cast. LOL Bob
