WD45 Front Loader Lift Capacity? |
Post Reply ![]() |
dpehrson ![]() Bronze Level ![]() Joined: 09 Jun 2012 Location: Preston,ID Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jun 2012 at 9:32am |
New to the forum and just purchased a WD45 w/ frontend loader. What is a realistic weight limitation for the bucket. Will it lift 1000 pounds?
Bob D. (La) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
I would say yes, but will be hard to steer and unless weight added, very light/poor traction.
Edited by Bob D. (La) - 09 Jun 2012 at 9:50am |
Thanks Bob D. for the reply...Just need to snag a generator that weighs about 1000 pounds and relocate it. Will be going very slow. Just wanted ask first before attempting...
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
I had one on a wd and honestly it would pick up 1500 but that was it. I know because I was picking up 14 inch h pile at seventy some pounds per foot , just be careful when you let it down because with a heavy load she drops quick |
jjpetrich ![]() Silver Level ![]() ![]() Joined: 06 Sep 2011 Location: Marshall, MN Points: 137 |
Lifted up a 2100 lbs bull up to the neck before a hose blew.
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3961 |
WD 90 loader was listed as 1500 lb lift capacity. and came with a 9 CF bucket. which is about 1100 lbs of manure. Mine with a set of wheel wieghts and a cab has no problem with 1000 lbs. it will get hard to steer. Rember to always carry your load as low as possable. f I need to move anything heavy more than just a few feet I lift it up back the trailer under and move it on the trailer.
Edited by Dakota Dave - 09 Jun 2012 at 10:56am |
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
cab?
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
Automatic Equipment Manufacturing company, Located in Pender Nebraska made this unaversial cab in the 1950's . I've seen them on several differant tractors.
almost looks like a grain box of an old gleaner. I like it. bet it's a lot better than a heat houser in the winter
German Shepherd dad
is that loader modified or bent?
German Shepherd dad
The loader is straight . But it has quite a bit of reinforcment welded to it. It is a lot better than a heat houser. the warm air from the engine blows bak and I don't need any more than normal street clothes. In the summer the canvas fwd part and rear door come off and the windows open.
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2494 |
It'll lift 1000 lbs easily.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Back when my pump was turned up a bit, I could push the rims to the ground with 35PSI in the front tires.
Thanks a million to all who have replied on the loader capacity post. I look forward to many good years in sharing the retirement years with this old girl doing the lifting by my side...
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Mine will lift enough to turn it over.Ben there, MACK
Post Reply ![]() |
