WD engine parts wanted
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Topic: WD engine parts wanted
    Posted: 13 May 2012 at 7:13pm
  Looking around for a connecting rod bolt and nut(cotter pin style), and a front crankshaft pulley. The pulley needs to be off a wide front so the hand crank will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 8:37pm
Isn't the pulley the same? The wide front on my 45 has a different end on crank rod to work at an angle to the pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 8:44pm
  No, the tractors with a narrow front use one part number, while the wide front and single wheels use another.  I've got a narrow front pulley, but the tractor has been converted to a wide front and the owner wants the handcrank to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2012 at 8:52pm
Can't speak to part #'s but I put a wide front under my originally narrow front 45 and the hand crank works the same pulley.
