head torque on head uc
johnny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnny Quote  Post ReplyReply Direct Link To This Post Topic: head torque on head uc
    Posted: 11 Dec 2009 at 10:22am
I have he service manual for the uc and while it talks about the head removal and replacement it does not give a figure for torque of head bolts it just says tight.  What do you think the torque should be.  Also I have never put any thing on a head gasket before and always had good luck should this gasket be coated with something prior to installlation?
thanks
johnny
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 1:50pm
Jonny head torque is 75 lbsft just be carefull with the drilled stud they do twist off. hth
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2009 at 2:35pm
Also start in the middle and work your way to the edges, and start at 60 and go up 5 each time through. I do not put anything on the gasket.
Leon B MO
