2600 disk vs something for rocks
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: 2600 disk vs something for rocks
    Posted: 27 Apr 2012 at 12:03am
Presently I'm using an AC 2300 18 ft doublefold (I have bent/dented a few blades due to the extra weight I have on it), but I'm considering going bigger and heavier. I've noticed the AC 2600 has much heavier blades but is a very solid disk (24 ft centerfold) and I have rocks, hills and peat sloughs. Both White and Massey have a stone/rock flex or spring cushion option on some of their models. (Haven't seen Deere) Does anyone have a suggestion or preference?    Will the AC 2600 handle rocks or is the spring cushion option a better choice?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 6:16am
Spring cushion as you call it is more appropriately known as the "Rock Flex" gang.......made for rocks. Consider a 2500 series which is way better than your 2300 and lighter than a 2600.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 7:22am
not Allis, but Kraus made a good rock-flex disc
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 7:40am
Howdy,
I had  AC 2600 24 foot with rock flew gangs. Worked very well with the rocks and heavy ground back in WI. The 2600 cut right in and half the time I never plowed.
Kurzy
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 7:23pm
The farm I work at has a 33ft. 2600 and they have a lot of rock in the fields and its not really too beat up.  As Kurzy said, the 2600 is an excellent cutting disk.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:38pm
Get a 1430 series sunflower had a centerfold disc once never again. Neighbor like his Krause
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:46pm
how big are them rocks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:47pm
i think...i'd invest ina rock picker...could pay for itself by selling the rocks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:49pm
a 1 ton rock will get you about 2-300 $$$ down here! small ones are a bout a .05 cents a pound!
This page was generated in 1.151 seconds.
