180 help
Fieldready View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fieldready Quote  Post ReplyReply Direct Link To This Post Topic: 180 help
    Posted: 03 Apr 2012 at 7:55am
Ok guys I'm looking for some help. I split my 180 at the torque housing and replaced the pto main shaft seals and reworked some broke pieces on the pto shifter lever. I put the tractor back together, but it won't pull now. It shifts thru the gears and barley moves when you release clutch. Is it possible I kinked the pickup lines on the clutch and it's not pulling fluid I checked level it's good. I even added more to make sure it was covering lines. Any help would be appreciated. I guess I'm going to have to re split it. Just looking to you fellas with more experience than me this is my first time splitting one watched my dad do it but it's way different when you start.   The reason I replaced seals was the hyd. Fluid was transferring to the transmission compartment. This is working now as is the pto tractor just won't move and this wasn't a problem when I split it. Thanks in advance.
