80-R mower lube??? |
Post Reply ![]() |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Apr 2012 at 4:35am |
I'm fixing up an 80-r mower, found a plug on top of round body smells like there was gear oil in it. What type should I use, and is it supposed to be full? Thanks, keith so. va.
Jim Lindemood ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Somebody will probably answer before I get back to you. My manual is in the barn -- not certain that I remember, but think they originally called for 20wt.oil -- but will have to check that.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I use 80 gear lube in mine.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2259 |
The manual says: Drive Housing: Capacity 1 Qt. SAE 20 or 30.
Do not let oil get below or do not fill above the driveshaft.
I got my mower long before I got a copy of the manual and
it had gear oil in it. Hasn't used any, so it's still in there.
Post Reply ![]() |
