roll over plow
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: roll over plow
    Posted: 31 Mar 2012 at 7:17pm
Going to use my 2 bottom roll over plow for the first time. how do you adjust it so that it  does a good job of turning over the ground?  still waiting on the manual for it to come.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 8:28pm
I found the if you drive one side of the tractor up on a 6X6 blocks, you can adjust the plow to lay flat on the ground. With a roll-over you do that on both sides. If yours is like mine, the bar that the lock pin snaps into is adjustable for each side. When I changed my plow to a different tractor, the rear of the left side was not penetrating far enough, so I loosened the bolt and pivoted the plow to compensate for that. Each bracket has a slot for adjusting. Bob
This page was generated in 0.062 seconds.
