WD steering shaft bushing replacement
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD steering shaft bushing replacement
    Posted: 07 Dec 2009 at 8:43pm
Is there a simple way to replace the upper steering shaft bushing (near throttle/lift quadrants) without removing the steering wheel?  I thought about just bending a piece of thin steel around the shaft and sliding it in place.  Would have to do something to it to keep it from sliding down the shaft.  I'm hoping you fellas have some better ideas?
Edited by Osage_Orange - 07 Dec 2009 at 8:46pm
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 8:48pm
Another option is to drive the pin out of the u-joint behind the frame rail and pull the wheel and shaft out, then put a new bushing in the quadrant.
Adam
