need advice - B hydraulic set-up
didgood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Topic: need advice - B hydraulic set-up
    Posted: 27 Mar 2012 at 11:27am
What do you guys use to go from the hydraulic pump to the two way valve body?  I picked up parts on ebay and the dude had thin wall tubing here, which isn't rated anywhere near the PSI that the pump will produce.
Also, what grade/material fittings should I use?
Thanks
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 2:06pm
I went to my local carquest where they make hydraulic hoses, I think mine was $25 for a 24" piece to my RAM.
Charlie
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 3:30pm
I got away with brake line for a few years until it cracked next to the flare.  If you're really careful not to scratch the tubing, or if you polish off any scratches before using it, you might be OK.  I was fortunate to find an NOS tube for mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 4:11pm
thanks for the tips
decided to have some custom hoses made up at a local joint - they specialize in all kinds of custom hydraulic applications
